[winGRASS] the " libgrass_gis.dll was not found !" problem
Huidae Cho
grass4u at gmail.com
Mon Dec 13 14:45:03 EST 2004
I really don't know the reason. I've uploaded a small script to fix the
problem at http://geni.ath.cx/grass.html
Thank you for your help.
Huidae Cho
On Mon, Dec 13, 2004 at 11:28:25AM +0200, Koukoulas Sotiris wrote:
> Yours does not work with me either...
> It seems however that the two files are slightly different...
> Cheers
> Sotiris
> -----Original Message-----
> From: Huidae Cho [mailto:grass4u at gmail.com]
> Sent: Monday, December 13, 2004 3:15 AM
> To: Koukoulas Sotiris
> Subject: Re: [winGRASS] the " libgrass_gis.dll was not found !" problem
> Before giving it up, could you send me your ps.map? And try the attached
> one.
> Thanks.
> Huidae Cho
> On Mon, Dec 13, 2004 at 01:44:44AM +0200, Koukoulas Sotiris wrote:
> > Ok many thanks for your efforts...
> > My Cygwin is the latest (I have actually installed everything from the
> > beginning). It seems that the solution with renaming the actual
> > libraries works ok for the time being - I can live with that for now
> > Cheers
> > Sotiris
> > Sent: Monday, December 13, 2004 12:48 AM
> problem
> > Hmm... I have no idea why your ps.map tries to locate
> > libgrass_(gis|I).dll. Mine doesn't do that.
> > Did you try to update cygwin packages?
> > Huidae Cho
> > On Sun, Dec 12, 2004 at 11:14:29PM +0200, Koukoulas Sotiris wrote:
> > > Ok, did what you said and here are the new outputs (no I did not
> > compile
> > > it myself - I used the binary that you provided, but it seems that
> it
> > > can not locate a couple of libraries: libgrass_gis.dll AND
> > > libgrass_I.dll...)
> > > ******************* OUTPUT 1
> > > $ cygcheck
> > /usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/bin/ps.map
> P:/cygwin/usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/bin/ps.map
> > > P:\cygwin\bin\cygwin1.dll
> > > C:\WINDOWS\system32\ADVAPI32.DLL
> > > C:\WINDOWS\system32\ntdll.dll
> > > C:\WINDOWS\system32\KERNEL32.dll
> > > C:\WINDOWS\system32\RPCRT4.dll
> > > .\libgrass_I.5.7.cvs.dll
> > > .\libgrass_vask.5.7.cvs.dll
> > > P:\cygwin\bin\cygncurses-8.dll
> > > .\libgrass_gis.5.7.cvs.dll
> > > P:\cygwin\bin\cygz.dll
> > > .\libgrass_datetime.5.7.cvs.dll
> > > .\libgrass_gmath.5.7.cvs.dll
> > > .\libgrass_symb.5.7.cvs.dll
> > > .\libgrass_gproj.5.7.cvs.dll
> > > P:\cygwin\bin\cygproj-0.dll
> > > P:\cygwin\usr\local\bin\cyggdal-1.dll
> > > P:\cygwin\bin\cygjasper-1-701-1.dll
> > > P:\cygwin\bin\cygjpeg-62.dll
> > > P:\cygwin\bin\cygpng12.dll
> > > P:\cygwin\bin\pq.dll
> > > P:\cygwin\bin\cygcrypt-0.dll
> > > P:\cygwin\bin\cygcrypto-0.9.7.dll
> > > P:\cygwin\bin\cygssl-0.9.7.dll
> > > P:\cygwin\bin\cygtiff4.dll
> > > Error: could not find libgrass_gis.dll
> > > Error: could not find libgrass_I.dll
> > > .\libgrass_vect.5.7.cvs.dll
> > > .\libgrass_dbmibase.5.7.cvs.dll
> > > .\libgrass_dbmiclient.5.7.cvs.dll
> > > .\libgrass_linkm.5.7.cvs.dll
> > > .\libgrass_rtree.5.7.cvs.dll
> > > .\libgrass_dgl.5.7.cvs.dll
> > > .\libgrass_dig2.5.7.cvs.dll
> > > ******************** OUTPUT 2
> > > GRASS 5.7.cvs:~ > d.m &
> > > [1] 3708
> > > GRASS 5.7.cvs:~ > Error in startup script: child process exited
> > > abnormally
> > > while executing
> > > "exec ps.map -p"
> > > (procedure "DmPrint::init" line 14)
> > > invoked from within
> > > "DmPrint::init"
> > > (procedure "main" line 30)
> > > invoked from within
> > > "main $argc $argv"
> > > (file
> > > "/usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/etc/dm/d.m.tcl"
> > line
> > > 875)
> > > [1]+ Exit 1 d.m
> > > GRASS 5.7.cvs:~ > cygcheck
> P:\cygwin\usr\local\grass5.7.cvs-i686-pc-cygwin-11_12_2004\lib\libgrass_
> > > I.5.7.cvs.dll
> > > vask.5.7.cvs.dll
> > > gis.5.7.cvs.dll
> > > gmath.5.7.cvs.dll
> > > symb.5.7.cvs.dll
> > > gproj.5.7.cvs.dll
> > > vect.5.7.cvs.dll
> > > linkm.5.7.cvs.dll
> > > rtree.5.7.cvs.dll
> > > dgl.5.7.cvs.dll
> > > dig2.5.7.cvs.dll
> > > GRASS 5.7.cvs:~ >
> > > Sent: Sunday, December 12, 2004 4:13 AM
> > > Cc: grass5 at grass.itc.it; wingrass at grass.itc.it; Patton, Eric;
> > > info at thomas-reinfelder.de
> > problem
> > > OK, ps.map seems to be able to find all libraries.
> > > But libgrass_gis.dll and libgrass_I.dll shouldn't be there. You
> know,
> > > linked libraries cannot be loaded at run-time because M$-Windows
> > doesn't
> > > support UNIX link. Instead, these linked libraries are used at
> > > compile-time. I don't know why your binary (should be the same as
> > mine)
> > > is linked against libgrass_gis.dll and libgrass_I.dll. Did you
> compile
> > > it yourself?
> > > Try the following:
> > > 1. Delete non 5.7.cvs.dll files and relink them:
> > > cd /usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/lib
> > > for i in `/usr/bin/ls | grep -v 5.7.cvs | sed 's/\.dll$//'`
> > > do
> > > rm -f $i.dll
> > > ln -s $i.5.7.cvs.dll $i.dll
> > > done
> > > 2. cygcheck
> > > Now, ps.map shouldn't be able to find libgrass_gis.dll. Right?
> > > Huidae Cho
> > > On Sun, Dec 12, 2004 at 03:40:26AM +0200, Koukoulas Sotiris wrote:
> > > > >Please check your library dependency of whatever command you run:
> > > > >cygcheck /usr/local/grass.../bin/ps.map
> > > > >Then it should print libraries that it requires. Try this in and
> > > > outside
> > > > >grass.
> > > > Done that and here are the results (all not found files exist!
> -see
> > > > lib_list attached):
> > > > 1. Outside grass on the cygwin prompt:
> > > > $ cygcheck
> > > > Error: could not find libgrass_I.5.7.cvs.dll
> > > > Error: could not find libgrass_gis.5.7.cvs.dll
> > > > Error: could not find libgrass_symb.5.7.cvs.dll
> > > > Error: could not find libgrass_gproj.5.7.cvs.dll
> > > > Error: could not find libgrass_vect.5.7.cvs.dll
> > > > 2. From grass5.7 prompt: -----------------------------------
> > > > GRASS 5.7.cvs:~ > cygcheck /usr/local/grass5.7.cvs-i686-pc-cygwin
> > > > I.5.7.cvs.dll
> > > > vask.5.7.cvs.dll
> > > > gis.5.7.cvs.dll
> > > > gmath.5.7.cvs.dll
> > > > symb.5.7.cvs.dll
> > > > gproj.5.7.cvs.dll
> > > > gis.dll
> > > > I.dll
> > > > vect.5.7.cvs.dll
> > > > linkm.5.7.cvs.dll
> > > > rtree.5.7.cvs.dll
> > > > dgl.5.7.cvs.dll
> > > > dig2.5.7.cvs.dll
> > > > GRASS 5.7.cvs:~ >
More information about the grass-windows
