[winGRASS] problem starting grass
Martin Perra
mperra at petrelrob.com
Fri Oct 8 14:55:59 EDT 2004
when I type "grass57" I get a popup titled "wish8.3.exe - unable to locate
component" The message says "This application failed to start because
cygwinb19.dll was not found. Re-installing the application may fix this
problem"
Any ideas?
Martin Perra, BSc., Geog.
Petrel Robertson Consulting Ltd.
#500, 736 - 8th Avenue S.W. Calgary, Alberta
T2P 1H4
(403) 218-1615
www.petrelrob.com
More information about the grass-windows
