[winGRASS] db driver problem?
Glynn Clements
glynn at gclements.plus.com
Sat Oct 23 23:03:31 EDT 2004
Huidae Cho wrote:
> Yeah, I agree with you. Nothing should be dependent on the behaviour
> of the linker.
> I found that there are no db_driver_* symbols in dbf.exe in the
> pre-compiled version.
In that case, either there was an error compiling db/drivers/dbf, or
you aren't looking hard enough (IIRC, Windows executables don't export
symbols unless you explicitly tell them to).
The dbf driver ($GISBASE/driver/db/dbf[.exe]) implements the following
functions itself:
db_driver_close_cursor
db_driver_close_database
db_driver_describe_table
db_driver_execute_immediate
db_driver_fetch
db_driver_finish
db_driver_get_num_rows
db_driver_init
db_driver_list_tables
db_driver_open_database
db_driver_open_select_cursor
Check the output from "make" to see whether db/drivers/dbf compiled
successfully.
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows
