[winGRASS] db driver problem?
Richard Greenwood
richard.greenwood at gmail.com
Sat Oct 30 23:49:15 EDT 2004
On Sat, 30 Oct 2004 21:37:44 -0500, Huidae Cho <grass4u at gmail.com> wrote:
> Hi,
> I have a problem with db drivers. How did you solve it in your
> distribution? Didn't you have the same problem?
> Thanks
> Huidae Cho
Attached is the shell script that I last used to configure 5.7 under
Cygwin a few months ago, and that (I think) was used to create the
bindist on grass.itc.it. Unfortunately it now generates errors in:
general/g3.region
raster/r.resamp.rst
raster3d/r3.showdspf
visualization/nviz
I would be very interested in seeing the configure options that you
are using. You seem to be way ahead of me. Keep up the good work!
Regards,
Richard Greenwood
www.greenwoodmap.com
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-windows/attachments/20041030/6e6644d5/_config.obj
More information about the grass-windows
