[winGRASS] compiling grass6.0.0beta2 on cygwin/grass6.0.0beta1
 on mingw
    Tyler Mitchell (tjm)
    tjm at timberline.ca
    Wed Feb  9 11:18:10 EST 2005
I'm not compiling, but downloading the beta binaries and got similar
run-time errors.  I relinked my files, but still no luck.  I then just
made a straight copy with the new file name and it worked no problem.
Is this related to the problem you guys brought up?  Seems there may be
an issue with linked files??
Tyler
Javier A. Yebrin wrote:
> (cc WINGRASS)
> Hi Marco, and developers:
> I think I've found a similar problem when trying to compile GRASS6 beta 1
> under MINGW. The first strange behaviour is that ./configure does'nt write
> the following variables in Platform.make :
> SHLIB_LD
> SHLIB_SUFFIX
> Leading to an error while making (I'm giving the example of making
> libgrass_gis), because there is no linker program to run. Editing these
> variables manually to:
> SHLIB_LD= gcc -shared
> SHLIB_SUFFIX= .dll
> Linking is done, but then at the final command an error occurs:
> [...] && ln -sf libgrass_gis.6.0.0beta1.dll
> /home/javier/grass_clean/dist.i686-pc-mingw32/lib/libgrass_gis.dll
> ln: creating symbolic link
> `/home/javier/grass_clean/dist.i686-pc-mingw32/lib/libgrass_gis.dll' to
> `libgrass_gis.6.0.0beta1.dll': No such file or directory
> make: ***
> [/home/javier/grass_clean/dist.i686-pc-mingw32/lib/libgrass_gis.6.0.0beta1.d
> ll] Error 1
> I've managed to work this out, adding the path to the grass libs in the
> Shlib.make like this:
> $(SHLIB): $(SHLIB_OBJS)
> 	$(SHLIB_LD) -o $@ $(LDFLAGS) $^ $(EXTRA_LIBS) && ln -sf
> /home/javier/grass_clean/dist.i686-pc-mingw32/lib/$(notdir $@) $(patsubst
> %.$(GRASS_VERSION_NUMBER)$(SHLIB_SUFFIX),%$(SHLIB_SUFFIX),$@)
> However, when compiling a single module, such as r.info, make (or the module
> itself) cannot find the needed libgrass libraries:
> "Imposible to find libgrass_gis.6.0.0beta1.dll" -> windows popup error
> There is a path/filename problem somewhere, and I think it is related to
> Marco's problem.
> Does anyone have a clue on this?
> Thanks in advance
> Javier
> -----Original Message-----
> From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it] On
> Behalf Of marco.lechner
> Sent: Wednesday, February 09, 2005 11:14 AM
> To: grass5 at grass.itc.it; wingrass at grass.itc.it
> Subject: [winGRASS] compiling grass6.0.0beta2 on cygwin
> Hi list,
> for the GRASS-User-Panel in Freiburg in 10 days I compiled a fresh Version
> from grass-6.0.0beta2 on my cygwin-machine and found this:
> ./configure with all the available works perfectly but during the make the
> compiler says that it couldn't find libgrass_*.6.0.cvs.dll - well of course
> I'm compiling the beta2 (as written in include/VERSION and all the produced
> grass-libs are named libgrass_*.6.0.0beta2.dll.
> If I edit the VERSION file to 6.0.cvs the whole compilation works perfectly
> (libgrass_*cvs.dlls are produced an found in the later compilation process)
> and I can install it with make install without any problems.
> Well - not a serious problem but how could this be?
> Why does the compiler think I'm compiling 0beta2 while creating the libs and
> later on it thinks why not searching for the cvs-Versions of the grass-libs?
> First I thought because of the existing VERSION~-file in include (it says
> cvs!) but deleating it, make distclean and all again from the beginning
> gives the same results. Where does the compiler get the "cvs"?
> Oh I forgot: the compiler asks for the wrong libs during compiling different
> modules (d.* g.* v.* r.*, . no difference)
> Any idea?
> Because I do not know if this is a cygwin or a 0beta2 problem I'm posting to
> both mailinglists
> Marco Lechner
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows
