[winGRASS] Re: help
Markus Neteler
neteler at itc.it
Sat Jan 29 01:09:32 EST 2005
I have slightly extended the HTML description to
"i.fusion.brovey performs a Brovey transformation on three multispectral and a panchromatic satellite image channels.
The command changes temporarily to the high resolution of the panchromatic channels for creating the three output channels, then restores the previous region settings. The current region coordinates are respected. The three pan-sharpened output channels may be combined with d.rgb or r.composite. "
Does it now explain better?
Markus
On Fri, Jan 28, 2005 at 02:36:57PM -0700, Natalie O'Toole wrote:
> Hi,
> Once I use the i.fusion.brovey pan sharpening command on Quickbird
> multispectral bands, is the output of this command one image with the four
> bands combined, or does it output more than one image? Is there any other
> command I have to run to get a pan sharpened single Quickbird image with
> multispectral and panchromatic bands merged?
> Thanks,
> Natalie
> This communication is intended for the use of the recipient to which it is
> addressed, and may
> contain confidential, personal, and or privileged information. Please
> contact the sender
> immediately if you are not the intended recipient of this communication,
> and do not copy,
> distribute, or take action relying on it. Any communication received in
> error, or subsequent
> reply, should be deleted or destroyed
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
More information about the grass-windows
