[winGRASS] "d.split" command options
Urko Careaga
olentzero77 at yahoo.es
Tue Jun 14 17:11:25 EDT 2005
Hello,
I have a problem with the frame command d.split:
When I use the command option:
Enter command to execute in 1st or 2nd frame
None of them are used by the program.
For example, in my case, I tried to apply
d.rast.leg instead of the d.rast default option.
Is there any problem with the selection of commands in
"d.split"?
Thank you,
Urko Careaga
______________________________________________
Renovamos el Correo Yahoo!
Nuevos servicios, más seguridad
http://correo.yahoo.es
More information about the grass-windows
