[grass4u@gmail.com: Re: [winGRASS] GRASS 6.0.0 release - libgrass*.6.1.cvs.dll not found]
    Huidae Cho
    grass4u at gmail.com
    Wed Mar 16 13:15:31 EST 2005
----- Forwarded message from Huidae Cho <grass4u at gmail.com> -----
Date: Wed, 16 Mar 2005 12:13:54 -0600
To: Marco Lechner <marco.lechner at geographie.uni-freiburg.de>
Subject: Re: [winGRASS] GRASS 6.0.0 release - libgrass*.6.1.cvs.dll not found
Message-ID: <20050316181354.GA796 at localhost.tamu.edu>
References: <20050313193522.GA605 at localhost.managednetworks.null> <BFEDJPBCMALKEGEEMPEJMEAECJAA.marco.lechner at geographie.uni-freiburg.de>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
In-Reply-To: <BFEDJPBCMALKEGEEMPEJMEAECJAA.marco.lechner at geographie.uni-freiburg.de>
User-Agent: Mutt/1.4.2.1i
Status: RO
Content-Length: 1709
Lines: 53
That's because of the GDAL library. To support r.out.gdal, I had to
compile my gdal library with grass support and it means gdal is linked
to a certain version of the grass library.
Download the corresponding file:
	for 6.0.0,	grass/gdal-grass6.0.0-1.2.3-1.tar.bz2
	for 6.0.cvs	grass/gdal-grass6.0.cvs-1.2.3-1.tar.bz2
	for 6.1.cvs	grass/gdal-grass6.1.cvs-1.2.3-1.tar.bz2
Huidae Cho
On Wed, Mar 16, 2005 at 03:59:30PM +0100, Marco Lechner wrote:
> Hi Cho, and wingrass-list
> I have a bug in 6.0.0 wich I can not reproduce. Well, if I install
> grass-6.0.0 (doesn't make a difference if I compile it by myself or if I use
> the Cygwin-Ibstaller and include your Cygwin-Mirror - I also tried it on a
> fresh mashine)
> When I start GRASS-6.0.0 after the Installation it gives the errormessage
> (see attached file): "The Application couldn't be started, becaous
> libgrass_gis.6.1.cvs.dll is not found" Of course it isn't installed in the
> 6.0.0-Version because the libraries are named libgrass*.6.0.0.dll.
> this problem started with Version 6.0.0beta2 (I always had to set the
> ../include/VERSION file to 6.0.cvs. I thought it's because 6.0.cvs was the
> Version before 6.0.0beta2, but the problem still goes on I couldn't realize
> how to fix it.
> Marco
> P.S. I tried to make the new CygwinGRASS-CD including 6.0.0 and 6.1.cvs -
> well 6.1.cvs works without problems but the described problems occur with
> Version 6.0.0
> Marco Lechner
> office:
> Department of Physische Geographie
> University of Freiburg
> Werderring 4
> D-79085 Freiburg
> Germany
> phone +49 (0)761 / 203-3548
> email marco.lechner at geographie.uni-freiburg.de
----- End forwarded message -----
More information about the grass-windows
