[winGRASS] display manager and monitors
    Huidae Cho
    grass4u at gmail.com
    Wed Mar 16 18:53:08 EST 2005
Can I see your /usr/X11R6/bin/startxwin.bat? This problem may be caused
by new cygwin x.org distribution.  What happens if you run startxwin.bat
and execute grass manually in xterm?
Huidae Cho
On Wed, Mar 16, 2005 at 08:31:35PM +0000, Richard Martin wrote:
> Hello List,
> If your on localhost with a single monitor, try this. Change the second
> line in the grass60.bat to: SET DISPLAY=:0. Don't omit the colon between
> the = sign and 0.
> Dick Martin
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows
