[winGRASS] Re: [GRASSLIST:1036] QGIS / GRASS for Windows 060508
Markus Neteler
neteler at itc.it
Fri May 12 15:49:31 EDT 2006
FYI
Radim is continuing to package (experimental) GRASS 6.1
with QGIS as *native* version for MS-Windows.
No Cygwin required...
M
On Mon, May 08, 2006 at 05:11:58PM +0200, Radim Blazek wrote:
> Here is the new package:
> http://mpa.itc.it/radim/wingrass/qgis-0.8.0-preview-win32-060508.zip
> The problem with NAD grid files did not exist in fact, I just
> tested with a file which was outside available grid files.
> There is however little problem with grid files, if GRASS plugin
> is loaded PROJ will search in qgis/grass/etc/nad even if
> qgis/shar/proj is available, the directories are currently identical
> so it cannot cause any problems for users.
> Radim
More information about the grass-windows
