[winGRASS] Re: winGRASS Digest, Vol 5, Issue 3
Jeremy Sears
searsj at inac-ainc.gc.ca
Mon Nov 27 15:03:54 EST 2006
Hi Isaac,
Thanks for the tips. It is very helpful.
Jeremy
>>> "Isaac Ullah" <isaac.ullah at asu.edu> 11/27/06 11:49 AM >>>
Hi Jeremy,
Your user profile for Grass is a file called ".grassrc6" that is created
in your home directory (ie. in windows: C:\msys\1.0\home\"username"\). If
you simply delete this file, then the "default" search path for your user id
will be deleted. Grass will create a new one when you restart it, and you
should then point it to your new Spearfish60 dataset that you have unzipped
to: C:\msys\1.0\home\grassdata\ . Make sure to highlight the "grassdata"
directory when locating it in the tree, but don't double click it...
Spearfish has two mapsets in it by default, PERMANENT and user1. You can
create a new one by typing a new name into the "create new mapset" space,
and clicking the button. If you make a new mapset, make sure that you will
be able to work with data in the other mapsets by going to menu item Config
--> Grass Working Environement --> Access other mapsets int he current
location, and selecting all the other mapsets...
Also, I read that another person was having trouble making new locations
in wingrass. Indeed, wingrass does not currently support the creation of new
locations at startup because an interactive text terminal is needed to
accomplish that, and the current release of wingrass does not support such
terminals (which is why aome other modules also fail to work in the current
relaease). To overcome this, just download the Spearfish dataset and follow
the instructions above. Once you have this, you can get into grass. Use GDAL
(file --> import --> raster files --> multiple formats using GDAL (or -->
vector files --> multiple formatrs using OGR))... Search for an existing GIS
file (ie. a geotiff or shapefile), and make sure to enter a name for the new
location to create using the spatial information stored in your GIS file.
Hit run, and your file will be imported into the location you just created.
Restart grass and make sure to select the new location (mapset PERMANENt,
will be created with your file, but you can create a new one if you are
unconforatble working in PERMANENT), and enter grass. You can now import
more data with the same projection info using the same methods outlined
above (GDAL/OGR) but be sure NOT to write a new location name this time. All
the data will then be imported into your current location (note: if the new
data's spatial extent (ie eastings and northings) exceeds the extents of
the first file you imported, you will need to check the box marked "extend
locations extents based on new data files". Otherwise your newly imported
data will be clipped to the same size as the first imported file).
Anyway, I hope this helps out..
Cheers,
Isaac Ullah
> Message: 8
> Date: Mon, 27 Nov 2006 12:57:19 -0500
> From: "Jeremy Sears" <searsj at inac-ainc.gc.ca>
> Subject: Re: [winGRASS] istallazione grass
> To: <wingrass at grass.itc.it>, "Matteo ..." <matteogeol at yahoo.it>
> Message-ID: <s56ae080.034 at SGW5HQ1.INAC.GC.CA>
> Content-Type: text/plain; charset=ISO-8859-1
> Hey,
> Thanks for the reply. Unfortunately I can't speak Italian,... However,
> I've managed to get GRASS to work. My problem was that I was unzipping the
> spearfish Dataset but selecting all the archived files within WinZIP and
> dragging them to my database folder. Extracting in this way doesn't maintain
> the original dir structure of the zip file, the result was all the files in
> one folder, rather than a folder containing the permanent and user1 folders.
> After extracting the files correctly, GRASS works.
> Thanks for the help.
> Jeremy
> >>> "Matteo ..." <matteogeol at yahoo.it> 11/27/06 10:44 AM >>>
> Qualcuno può spiagarmi in maniera semplice come si istalla Grass nel
> sistema operativa Windows XP ?
> Ho seguito la procedura trovata nel sito
> http://geni.ath.cx/grass.html#toc2
> istallando cygwin ma seguendo le indicazioni del punto 3 (Add
> http://geni.ath.cx/grass to the user URL) a un certro punto leggo che
> l'URL non funziona
> __________________________________________________
> Do You Yahoo!?
> Poco spazio e tanto spam? Yahoo! Mail ti protegge dallo spam e ti da tanto
> spazio gratuito per i tuoi file e i messaggi
> http://mail.yahoo.it
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
> End of winGRASS Digest, Vol 5, Issue 3
Isaac I Ullah, M.A.
Archaeology PhD Student,
ASU School of Evolution and Social Change
Research Assistant,
Mediterranean Landscape Dynamics Project
ullah at archaeologist.com
http://www.public.asu.edu/~iullah
More information about the grass-windows
