[winGRASS] grass.bat not found
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Mon Oct 9 12:36:44 EDT 2006
thanks Huidae, now it works - I made the mistake to unzip the files and after
deleting /inst_grass and executing the bat file again, GRASS was sucessfully
installed - however now other problems occur but my colleague will
address this
mailing list directly.
Martin
Quoting Huidae Cho <grass4u at gmail.com>:
> The following email exchange will help you:
> From: david welch <curlygrape at hotmail.com>
> To: grass4u at gmail.com
> Subject: download successful
> Date: Wed, 20 Sep 2006 19:15:30 +0000
> download was successful
> It installed after I deleted the inst_grass folder that was left on my c
> directory.
> thanks
> David
>> From: Huidae Cho <grass4u at gmail.com>
>> To: david welch <curlygrape at hotmail.com>
>> Subject: Re: [winGRASS] trouble installing grass
>> Date: Wed, 20 Sep 2006 13:17:35 -0500
>> On Wed, Sep 20, 2006 at 05:56:54PM +0000, david welch wrote:
>>> thanks huidae
>>> I've placed the inst_grass.bat wget-1.10.2b.zip and unzip.exe in
>> c:\inst_grass
>>> and after running the .bat I get a series of messages like
>>> unzip: cannot find either /inst_grass/libiconv-1.9.2-1-bin.zip or
>>> /inst_grass/libiconv-1.9.2-1-bin.zip.zip
>>> there are about 29 or so lines that come up with various files it cannot
>> find
>>> any suggestions?
>> There was a bug in inst_grass.bat, which is now fixed. Please download
>> inst_grass.bat and retry. Note that c:\inst_grass is supposed to be
>> created by inst_grass.bat, so you have to put inst_grass.bat, wget, and
>> unzip in another directory.
>> Huidae
>>> david
>>> >CC: wingrass at grass.itc.it
>>> >Date: Wed, 20 Sep 2006 11:28:47 -0500
>>> >On Wed, Sep 20, 2006 at 03:07:40PM +0000, david welch wrote:
>>> >> HI,
>>> >> I have been attempting to launch grass on my windows machine but have
>> been
>>> >> unable to do so.
>>> >> in one of the last steps of the installation, you are supposed to run a
>>> >batch
>>> >> file in a directory, along with unzip-1.exe and wget-1.10.2b.zip
>>> >> I get the message: '\inst_grass\unzip' is not recognized as an internal
>> or
>>> >> external command, operable program or batch file.
>>> >Where did you get that unzip-1.exe? It should be unzip.exe. Check if
>>> >you have c:\inst_grass\unzip.exe and if not, just try to copy
>>> >unzip-1.exe to c:\inst_grass\unzip.exe and run inst_grass.bat again.
>>> >Huidae
>>> >> thanks
>>> >> david
>>> >> _______________________________________________
>>> >> winGRASS mailing list
>>> >> winGRASS at grass.itc.it
>>> >> http://grass.itc.it/mailman/listinfo/wingrass
> On Sat, Oct 07, 2006 at 01:48:59PM +0200, Martin Wegmann wrote:
>> Dear win-GRASS users,
>> I have to install GRASS for a colleague.... but on windows.
>> It is great that the installation for windows is becoming easier,
>> but I still
>> run into a few problems (probably because I am used to the Linux way)
>> I downloaded all files into c:/grass and installed them as described at
>> http://geni.ath.cx/grass.html
>> However, when I run inst_grass.bat I get the message:
>> /inst_grass/sqlite-3.3.6-1.zip or /inst_grass/sqlite-
>> 3.3.6-1.zip.zip.
>> unzip: cannot find either /inst_grass/xdr-4.0-1.zip
>> or /inst_grass/xdr-4.0-1.zi
>> p.zip.
>> unzip: cannot find either /inst_grass/grass.zip or
>> /inst_grass/grass.zip.zip.
>> Das System kann die angegebene Datei nicht finden.
>> GRASS installation completed.
>> Run c:\msys\1.0\grass.bat to start the GRASS GIS
>> Manager.
>> However in c:\msys\1.0\ there is no grass.bat file.
>> This problem has been addressed before but I could not find any replies.
>> What I do not understand is this part:
>> >If you have already installed the first release (2006-09-13), please update
>> >grass/gdal-1.3.2-1.zip and grass/sqlite-3.3.6-1.zip too. Download
>> these files
>> >along with grass/grass-2006-09-17.zip and uncompress/overwrite old
>> files under
>> >C:\msys\1.0\local.
>> What shall I do if this is my first windows installation? Just download
>> grass-2006-09-17.zip nothing else?
> If it's your first install, you should follow the whole steps in the
> instruction.
> Huidae
>> Thanks in advance, Martin
>> Martin Wegmann <wegmann at biozentrum.uni-wuerzburg.de>
More information about the grass-windows
