[winGRASS] running cygwin/grass 6.1, 6.2 and native 6.3 on the
same xp machine
Luigi Ponti
lponti at infinito.it
Wed Aug 8 08:34:16 EDT 2007
Glynn Clements wrote:
> Luigi Ponti wrote:
>> I am currently still with the 6.1cvs cygwin/grass binaries but would
>> like to run the cygwin 6.2.1 and the native 6.3 versions of grass for
>> testing purposes on the same windows xp machine.
>> To my knowledge, different cygwin/grass versions use different cygwin
>> packages, and the native wingrass requires setting environmental
>> variables that may interfere with the cygwin version.
>> Is there any precautionary measures I should take in order to avoid
>> interference between the different versions and to be able to test newer
>> versions without losing the ability of working with the old one?
> There shouldn't be any problem with having multiple Cygwin builds of
> GRASS. If there is, I'd suggest moving to 6.2.1. The 6.1 branch ended
> with the release of 6.1.0; there won't be any updates.
> As for conflicting environment variables: I suggest editing MSys'
> /etc/profile (or ~/.profile etc) to explicitly clear any
> Cygwin-related settings. Specifically, unset the CYGWIN variable;
> there shouldn't be any other applicable variables.
Thanks Glynn:
Really an authoritative reply -- I couldn't ask for anything more.
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20070808/7904ce38/attachment.html
More information about the grass-windows
