[winGRASS] Re: [GRASS-user] Native wingrass-6.3.cvs
Ted Nebitko tnebitko at can.rogers.com
Mon Aug 27 07:32:07 EDT 2007
Re: [GRASS-user] Native wingrass-6.3.cvsThank you for the response.
I got wingrass63_cvs20070825.zip25-Aug-2007  to work by adding "set path="%wingisbase%\etc\init.bat" %* (last line of grass63.bat) and then using init.bat to start the application.
  ----- Original Message -----
  To: Ted Nebitko ; wingrass at grass.itc.it ; grassuser at grass.itc.it
  Sent: Friday, August 24, 2007 11:04 AM
  Subject: Re: [GRASS-user] Native wingrass-6.3.cvs
  My first guess would be some kind of path problem. I'm not sure how this is set with WinGRASS, but it sounds like it can't find the /bin directory within GRASS.
  Michael.
  On 8/23/07 7:46 AM, "Ted Nebitko" <tnebitko at can.rogers.com> wrote:
      I downloaded wingrass63_cvs20070820.zip  <http://moritz.homelinux.org/grass/wingrass/wingrass63_cvs20070820.zip> <http://moritz.homelinux.org/grass/wingrass/wingrass63_cvs20070820.zip> 20-Aug-2007 16:37 23M version and and launched the file to the c:\  drive. Using cmd and grass63.bat, I got the opening gui where the location and  mapset (spearfish60) were placed. But when "enter grass" was pressed the  following "error in startup script' occurred.
      .ERROR: program 'g.gisenv' cannot be executed because: Neither a  command line (cmd) or interactive (inter) version was found.
      mail: not  found while executing "exec g-gisenv get=GISDBASE" invoked from within
      "set env(GISDBASE) [exec g.gisenv get=GISDBASE]"
      (file  "c:/grass/grass-6.3.cvs\etc\gm\gm.tcl" line31)
    I have cygwin Grass6.0.cvs running successfully on my d:\ drive  and the two grassrc6 files do not appear to conflict since they are on separate drives.
  Michael Barton, Professor of Anthropology
  Director of Graduate Studies
  School of Human Evolution & Social Change
  Center for Social Dynamics & Complexity
  Arizona State University
  phone: 480-965-6213
  fax: 480-965-7671
  www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20070827/5a3b651e/attachment.html
More information about the grass-windows mailing list
