No subject
    Wed Nov 14 17:04:00 EST 2007
distinction of Cygwin / Xfree or you mixed them up
to save word space.
Cygwin http://sources.redhat.com/cygwin is a unix
environment that runs under windows and the Xfree
http://cygwin.com/xfree/ is a port of the X window
system using cygwin.  This port includes all the
libraries for development.
The X server that comes with the Cygwin port of Xfree
is the subject of your comparison with X-win32.
I have used X-win32 and have a license to use it.
When I upgraded to the version 5.0, I had problems
with Grass and some of my other applications.  As a
result I still use version 411 of X-win32.  Initially
I thought it was the X11R6 of X-win32 that was causing
the problems but it may also be the .Xdefaults file
which controls the fonts.  I did not look further
into it since version 411 works and I'm more
interested in application development than in
debugging system level functions; although I have
fixed several of the X library functions in the
past.
John
-----Original Message-----
From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
Behalf Of Ben White
Sent: Thursday, June 20, 2002 9:59 AM
To: 'wingrass at grass.itc.it'
Subject: [winGRASS] RE: X-Win32 versus Cygwin
Sorry I should have specified X-Win32.
--Ben
Hi List--
Not being a CS person myself, has anyone on the list attempted the install
of GRASS on a PC running X-Win as opposed to Cygwin?  If so, which build did
you use and have you had relatively good results?
Thanks in advance,
Ben
winGRASS mailing list
winGRASS at grass.itc.it
http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows
