[winGRASS] v.db.addcol
    Moritz Lennert
    mlennert at club.worldonline.be
    Wed Nov  7 10:57:16 EST 2007
On 07/11/07 11:00, Moritz Lennert wrote:
> Nicola,
> On 06/11/07 19:47, Nicola Zoppetti wrote:
>> In the folder
>> $GISDBASE/$LOCATION_NAME/$MAPSET/.tmp/
>> three temporary dbf files are created,
>> one with the 'a' column added, one with the 'b' column added and the last
>> one with the 'c' column added.
>> It happens exactly the same if I directly use the db.execute command:
>> echo "ALTER TABLE ed7m3uT ADD COLUMN a double" | db.execute
>> echo "ALTER TABLE ed7m3uT ADD COLUMN b double" | db.execute
>> echo "ALTER TABLE ed7m3uT ADD COLUMN c double" | db.execute
>> If I manually add the three columns to the dbf table and I try to fill
>> the
>> empty fields with the v.to.db command, once again a temporary table in
>> the
>> .tmp folder is correctly created and filled but the table linked to the
>> features, in the folder 'dbf' of the mapset, remains unchanged.
>> Is there something that doesn't work as it should or I'm doing something
>> wrong??
> No, I can confirm that problem. You apparently discovered a
> window-related bug in db.execute.  I'll look into it.
> Thank you very much for reporting.
Just to keep you posted:
I have narrowed down the issue a bit: the problem only occurs with the
dbf driver, not with postgresql or sqlite. Up to now I have seen that
inserts and updates do not work.
Will look further.
Moritz
More information about the grass-windows
