FW: [winGRASS] V.digit issues with TCL
Sampson, David dsampson at NRCan.gc.ca
Fri Nov 9 09:25:20 EST 2007
One other message I get is a "Error is startup script" dialogue
can't find package BWidget 1.2.1 while executing
"package require -exact BWidget 1.2.1"
(file "c:\GRASS\grass\grass-6.3.cvs/etc/v.digit/toolbox.tcl" line 2)
[mailto:wingrass-bounces at grass.itc.it] On Behalf Of Sampson, David
	Sent: Friday, November 09, 2007 09:14
	To: wingrass at grass.itc.it
	Subject: [winGRASS] V.digit issues with TCL
	Hey Folks,
	Trying some new functions with the GRASS win binary.
	I can use the GUI no problem, but todays issue is with v.digit.
	I have one vector file of a road network loaded.  I wanted to do
some edits to find nodes and such manualy as v.to.points for nodes and
vertices returned nothing.
	I got a message saying the v.digit could not find init.tcl
	My TCL is in C:\Tcl\lib\tcl8.4
	And the file exists, but the directory is never checked....
	Instead it tries to look in my apache2triad directory and a
bunch of GRASS directories.
	I tried putting ina shortcut from the apache2triad directory to
connect (sorta line a symbolic link in linux) but no glory. I also
created a TCL env variable and added it to the path, still nothing.
	The message ends "This probably means that TCL wasn't installed
properly"
	I believe I followed the extra install steps....
	The following is my batch file
	@echo off
	rem
	rem #
	rem #           GRASS Initialization
	rem #
	rem
	rem *******Environment variables***********
	rem Uncomment and set the following values if they differ from
the indicated default
	rem Directory where your .grassrc6 file will be stored
	rem set HOME=%USERPROFILE%
	rem Name of the wish (Tk) executable
	rem set GRASS_WISH=wish.exe
	rem Path to the shell command
	set GRASS_SH=c:\msys\1.0\bin\sh.exe
	rem Path to your web browser
	rem set
GRASS_HTML_BROWSER=%SYSTEMDRIVE%\PROGRA~1\INTERN~1\IEXPLORE.EX
	set GRASS_HTML_BROWSER=C:\Program Files\Mozilla
Firefox\firefox.exe
	rem Path to the proj files (notably the epsg projection list)
	rem set GRASS_PROJSHARE=\c\grass\share\proj
	set GRASS_PROJSHARE=C:\GRASS\grass\share\proj
	set WINGISBASE=c:\GRASS\grass\grass-6.3.cvs
	"%WINGISBASE%\etc\init.bat" %*
	All the regualr windows can find TCL just fine... am I missing
something else?...
	Is this a script thing, a python thing, an environemnt variable
thing
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20071109/7b48f373/attachment.html
More information about the grass-windows mailing list
