[GRASS-dev] Re: [GRASS-windows] Problems with Mapcanvas
Hamish
hamish_nospam at yahoo.com
Tue Nov 20 20:15:48 EST 2007
> Doug_Newcomb wrote:
> > Contents of PERMANENT/PROJ_INFO file:
> > name: Lambert Conformal Conic
> > proj: lcc
> > datum: nad83
> > ellps: grs80
> > lat_1: 36.16666666666666
> > lat_2: 34.33333333333334
> > lat_0: 33.75
> > lon_0: -79
> > x_0: 609601.22
> > y_0: 0
> > no_defs: defined
> > towgs84: 0.000,0.000,0.000
Glynn:
> That doesn't tell me the one thing I really need to know: whether
> there are CR characters in the file.
> Try "od -t x1z PROJ_INFO"; look for any occurrences of "0d" in the
> output.
perhaps this patch helps:
Index: lib/gis/key_value2.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/key_value2.c,v
retrieving revision 2.3
diff -u -r2.3 key_value2.c
--- lib/gis/key_value2.c 14 Apr 2007 23:01:59 -0000 2.3
+++ lib/gis/key_value2.c 21 Nov 2007 01:11:54 -0000
@@ -32,7 +32,7 @@
kv = G_create_key_value();
if (kv == NULL)
return NULL;
- while (G_getl(buf, sizeof buf, fd) != 0)
+ while (G_getl2(buf, sizeof buf, fd) != 0)
key = value = buf;
while (*value && *value != ':')
also, should that be using "(buf, sizeof(buf)-1, fd" ?
Hamish
____________________________________________________________________________________
Be a better sports nut! Let your teams follow you
with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
More information about the grass-windows
