[winGRASS] grass6.3cvs and the shell
endrizzi at ing.unitn.it
Fri Oct 12 01:14:26 EDT 2007
Hi everybody!
I have installed wingrass 6.3cvs (as suggested by
http://moritz.homelinux.org/grass/wingrass/README). The installation is
ok, but, when I launch grass63.bat, it does not load the shell msys. I
would ask your help. Actually I have changed grass63.bat as suggested, in
this way:
@echo off
rem #########################################################################
rem #
rem # GRASS Initialization
rem #
rem *******Environment variables***********
rem Uncomment and set the following values if they differ from the
indicated default
rem Directory where your .grassrc6 file will be stored
rem set HOME=%USERPROFILE%
rem Name of the wish (Tk) executable
rem set GRASS_WISH=wish.exe
rem Path to the shell command
set GRASS_SH=c:\msys\1.0\bin\sh.exe
rem Path to your web browser
rem set GRASS_HTML_BROWSER=%SYSTEMDRIVE%\PROGRA~1\INTERN~1\IEXPLORE.EX
rem Path to the proj files (notably the epsg projection list)
rem set GRASS_PROJSHARE=\c\grass\share\proj
set WINGISBASE=c:/grass/grass-6.3.cvs
"%WINGISBASE%\etc\init.bat" %*
Is it correct, or do I forget something?
I have noticed that from the help menu it does not load internet explorer
(even if I uncomment the line at GRASS_HTML_BROWSER).
I have also noticed that the legend numbers are not displayed.
Even if I checked the previous messages in mailing list, I hope that these
problems have already been discussed.
Thanks,
Stefano
More information about the grass-windows
