[winGRASS] Re: Re: issue with 6.3 RC1 binary
Doug_Newcomb at fws.gov
Tue Oct 30 08:49:20 EDT 2007
>Odd. In most cases, the user's "Documents and Settings" directory (the
>exact name varies according to language) is more likely to work than
>the root directory.
>Users with networked home directories will typically want their GRASS
>configuration saved there.
>If HOME is unset, the default is to set it to %USERPROFILE%, which I
>would normally expect to be writable.
Just for fun, I set the Home to the c:\New Folder directory , that I
created. I had no problems creating the .grass6 file in that directory,
so spaces in the directory name are not the problem.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of Interior.
Life is too short for undocumented, proprietary data formats.
Glynn Clements
<glynn at gclements.
plus.com> To
10/29/2007 06:53 cc
PM wingrass at grass.itc.it
Subject
Re: [winGRASS] Re: Re: issue with
6.3 RC1 binary
Doug_Newcomb at fws.gov wrote:
> >> Hi,
> >> I downloaded and Activestate's TCL and msys per the cvs
instructions
> >> and then unzipped the Grass 6.3RC1 file under c:. When I start the
> >> grass6.3.bat file and try to create a location I get :
> >> couldn't open "C:/Documents and
Settings/dnewcomb.usfwsral3/.grassrc6":
> >> permission denied
> >Could you try in a path without white space? Just to know...
> >Markus
> Markus,
> I set :
> HOME = c:\
> in the grass63.bat file and it fixed the problem. my apologies for
> misunderstanding your reply. Something to put in the release notes?
the root directory.
More information about the grass-windows
