[winGRASS] Starting grass command from cmd.exe
Markus Neteler
neteler at itc.it
Tue Sep 4 16:02:42 EDT 2007
In recent CVS versions, a grass63.bat file is generated. It is based on this
template:
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass6/lib/init/grass.bat?rev=HEAD
Maybe you can pick relevant entries from that file.
Markus
François-Xavier PRUNAYRE wrote:
> Hi list, Im new to grass on windows and Im wandering if theres any way
> to
> have grass command running directly from cmd.exe without starting grass.
> Ive this up&running on linux setting env variable.
> I tried the same on windows but cant get it works. :-(
> I added : C:\grass\grass-6.3.cvs\bin and C:\grass\grass-6.3.cvs\lib to
> PATH
> Defined : GISBASE, GRASS_GUI, LOCATION_NAME and MAPSET variables
> Any ideas ?
> Thanks a lot for your help.
> Francois
View this message in context: http://www.nabble.com/Starting-grass-command-from-cmd.exe-tf4378808.html#a12485585
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows
