[GRASS-windows] v.6.4 regex compilation problem
Markus Neteler neteler at osgeo.org
Tue Dec 30 13:23:32 EST 2008
On Tue, Dec 30, 2008 at 7:01 PM, Robert Szczepanek <robert at szczepanek.pl> wrote:
> Thanks Markus,
>> the regex stuff was added as test (AFAIR). On grass-dev, there was
>> a related posting:
>> >> TODO:
>> >> * compile with regex
>> > I can report it works fine with the Gnuwin32 regex packages.
>> Perhaps you could try this and report back?
>> Markus
> Having no experience with packages I did at the moment just
> --without-regex
which should be ok as it is almost unused.
> and
> Finished compilation: Tue Dec 30 17:45:59 GMT 2008
> Errors in:
Compare here:
http://grass.osgeo.org/wiki/WinGRASS_Current_Status#Known_Issues
> /usr/local/src/grass-6.4.0/raster/r.li/r.li.daemon
can you go into r.li.daemon and compile and publish
the error?
> /usr/local/src/grass-6.4.0/raster/r.li/r.li.*
don't compile since the first is missing (AFAIK).
Markus
More information about the grass-windows mailing list
