[GRASS-windows] WinGRASS cvs snapshot compilation
ines_cherif
ines_cherif at voila.fr
Tue Feb 5 06:50:27 EST 2008
Hi all,
I'm trying to compile the GRASS cvs snapshot on windows.
Below is the output from compilation.
It seems there is a problem with flex while I have installed GnuWin32 flex and bison.
Any idea what is going wrong?
Thanks,
$ configure
checking host system type... i686-pc-mingw32
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for Cygwin environment... no
checking for mingw32 environment... yes
checking for executable suffix... .exe
checking for full floating-point support... yes
checking for pwd... /bin/pwd
checking for source directory... /c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2007_12_01
checking for build directory... /c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2007_12_01
checking for MacOSX App... no
checking how to build libraries... shared
checking for ranlib... ranlib
checking how to run the C preprocessor... gcc -E
checking if 64bit support is requested... no
checking if 64bit Sparc VIS support is requested... no
checking system version (for dynamic loading)... MINGW32_NT-5.1-1.0.11(0.46/3/2)
checking for dlopen in -ldl... no
checking for ar... ar
checking for additional include dirs...
checking for additional library dirs...
checking for a BSD compatible install... /bin/install -c
checking for flex... lex
checking for yywrap in -ll... no
checking for lex... no
configure: error: *** Unable to locate lex.
More information about the grass-windows
