[GRASS-windows] WinGRASS: Error with c++ compiler
ines_cherif ines_cherif at voila.fr
Thu Feb 7 06:02:45 EST 2008
Thanks, the problem has been fixed by installing the "gcc-g++" package.
I then compiled with make and got the errors below.
Any idea of what to do in order to get rid of these errors?
build_html_index.sh
Generating HTML manual pages index (help system)...
Generated HTML docs in ../dist.i686-pc-mingw32/docs/html/index.html
Following modules are missing the 'description.html' file in src code:
GRASS GIS compilation log
Started compilation: Thu Feb  7 12:08:09 GTBST 2008
Errors in:
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/imagery/i.atcorr
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/imagery/i.class
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/imagery/i.ortho.photo/photo.2image
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/imagery/i.ortho.photo/photo.2target
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/imagery/i.points
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/imagery/i.vpoints
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.daemon
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.edgedensity
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.patchdensity
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.patchnum
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.shape
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.simpson
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.shannon
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.mps
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.mpa
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.padcv
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.padsd
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.padrange
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.cwed
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.richness
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.li/r.li.dominance
/c/grass63RC3/grass-6.3.cvs_src_snapshot_2007_12_01/grass-6.3.cvs_src_snapshot_2                                                            007_12_01/raster/r.terraflow
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Thu Feb  7 12:32:52 GTBST 2008
make: *** [default] Error 1
More information about the grass-windows mailing list
