[GRASS-windows] Error: Redirection is not supported
    Glynn Clements
    glynn at gclements.plus.com
    Sat Feb  9 15:29:02 EST 2008
Frank Warmerdam wrote:
> >>> I gave the 6.3.0RC4 wingrass binaries a spin.  But when I run the
> >>> grass63 shell script
> >> Windows is supposed to use the grass63.bat file (which invokes
> >> init.bat); I don't know whether Init.sh is meant to be supported under
> >> Windows.
> > Glynn,
> > OK, if I tried from cmd.exe I get:
> > c:\warmerda\grass63RC4\bin>grass63.bat
> > grass63.bat
> > access: Invalid argument
> > ERROR: LOCATION << c:/warmerda/grass63RC4/bin/<UNKNOWN> >> not available
> > '"wish.exe"' is not recognized as an internal or external command,
> > operable program or batch file.
> > Am I supposed to have a grass database setup before I run things?
> Sorry for being a bit clueless, I meant to run in -text mode.  When I do
> I get:
> c:\warmerda\grass63RC4\bin>grass63.bat -text
> grass63.bat -text
The "ERROR: LOCATION << .../<UNKNOWN> >> not available" is a known
issue with the startup. If the startup fails, you can end up with a
bogus ~/.grassrc6 file, which needs to be manually deleted before you
can use GRASS again.
[If %HOME% isn't already set, it will be set to %USERPROFILE%, which
is typically C:\Documents and Settings\<username>.]
The issue isn't specific to Windows, although it's more common there.
> Redirection is not supported.
> I'm *presuming* the redirection not supported is coming from the
> set_data program.
I don't think that it's being generated by GRASS directly. It's more
likely that bad data is finding its way into a system component.
More information about the grass-windows
