[GRASS-windows] native grass63RC4 and MSYS shell
Mirko Baruffini
mirko.baruffini at supsi.ch
Mon Feb 11 10:39:38 EST 2008
Thank you Moritz!
Now it works! I have modified the file bin/grass63 as you told me. But
the scipts run only in text mode....
Can I also run them with a GUI?
Can you help me?
Mirko
Moritz Lennert ha scritto:
> On 08/02/08 22:11, Glynn Clements wrote:
>> Mirko Baruffini wrote:
>>> I' m using wingrass grass63RC4. The use is ok, but, when I launch
>>> grass63.bat, it does not load the shell msys (I have uncommented and
>>> adapted some of the environment variables in grass/bin/grass63.bat).
>>> So i decided to launch a script with native wingrass launching grass
>>> from within the msys shell.
>>> When I type /c/grass/bin/grass63 it does not load grass. On the
>>> sceen I can read:
>>> mirko.baruffini a ISTPC29 /
>>> $ /c/grass63RC4/bin/grass63
>>> /c/grass63RC4/grass-6.3.0RC4/etc/Init.sh: uname: command not found
>>> /c/grass63RC4/grass-6.3.0RC4/etc/Init.sh: mkdir: command not found
>>> Cannot create temporary directory! Exiting.
>>> But the command uname exists:
>>> $ uname
>>> MINGW32_NT-5.1
>>> What could I do?
>> AFAIK, starting GRASS or running GRASS commands from the MSys shell is
>> unsupported under Windows.
> No, it should work. I cannot reproduce the above error messages.
> However, to make the current 63RC4 package work, you have to change
> the bin/grass63 file from
> GISBASE=c:/grass63RC4/grass-6.3.0RC4
> to
> GISBASE=/c/grass63RC4/grass-6.3.0RC4
> Then it works well for me (not everything tested, though).
>> Unfortunately, MSys shell provides an environment which is somewhere
>> between Unix and Windows, and not entirely compatible with either. In
>> particular, any pathnames which GRASS sees will need to be compatible
>> with Windows, e.g. C:\path\to\file or C:/path/to/file rather than
>> MSys' /c/path/to/file convention.
> Well, actually, as you can see above, for launching grass you need the
> msys style.
>> The focus of WinGRASS is to produce a *native* Windows version. Unless
>> you're building WinGRASS yourself, you shouldn't need MSys for
>> anything other than running shell scripts.
> And even then, I guess other shells would also do the trick, such as
> Gnuwin32's shell and tools such as awk and sed. Msys is more
> convenient as the default installation contains these tools.
> Moritz
More information about the grass-windows
