[GRASS-windows] Re: [GRASS-dev] Re: [GRASS-trac] #13: GRASS
	OGRModule failing
    Jonathan Aguero-Valverde
    jua130 at psu.edu
    Wed Jan  9 10:35:23 EST 2008
Moritz
I have Vista, Activetcl 8.4.14.0 and WinGRASS 6.3 cvs 2007.12.14.
I followed the instructions from readme file and used the binaries.
Now, I also have a system with the same tcl and winGRASS but with XP and it
has no problems with the dbf driver so I guess it is a VISTA problem.
Research Assistant and Ph.D. Candidate
Pennsylvania State University
The Pennsylvania Transportation Institute
201 Transportation Research Building
University Park, PA 16802
www.personal.psu.edu/jua130
----- Original Message -----
From: "Moritz Lennert" <mlennert at club.worldonline.be>
To: <grass-windows at lists.osgeo.org>
Cc: <jua130 at psu.edu>
Sent: Wednesday, January 09, 2008 5:15 AM
Subject: [GRASS-windows] Re: [GRASS-dev] Re: [GRASS-trac] #13: GRASS
OGRModule failing
> CC'ing to Jonathan who was the first to report this...
> On 08/01/08 03:56, GRASS-trac wrote:
>> #13: GRASS OGR Module failing
>>   Reporter:  jrobins  |       Owner:  grass-dev at lists.osgeo.org Type:
>> defect   |      Status:  new                       Priority:  major    |
>> Milestone:  6.3.0                     Component:  default  |     Version:
>> svn-trunk                 Resolution:           |    Keywords:
>> OGR,Cygwin,winGRASS,Tcl/Tk
>> Changes (by jrobins):
>>   * keywords:  OGR,Cygwin => OGR,Cygwin,winGRASS,Tcl/Tk
>>   * version:  unspecified => svn-trunk
>>   * milestone:  => 6.3.0
>> Comment:
>>  I also get a similar error in the latest 6.3.svn release (built December
>>  14)
>>  from the winGRASS project.  After opening the PERMANENT mapset of the
>>  spearfish60
>>  data, I ran "v.out.ogr input=roads type=line dsn=/shapefiles
>>  olayer=Roads".  This
>>  generates the following error messages:
>>  Invalid argument: can't _spawnl
>>  ERROR: Unable to start driver <dbf>
>>  The module then exits.  I ran this from both the text version and Tcl/Tk
>>  gui with
>>  the same result.  My current Tcl version is 8.4.16.0.282109.
> I cannot reproduce this problem, so we will have to find out what is
> different in your respective setups from mine.
> Could you give me details of how exactly you installed winGRASS ? Do you
> also have the cygwin version installed ?
> At this stage I have no idea what might be causing this...
> Moritz
> grass-windows mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-windows
More information about the grass-windows
