[GRASS-windows] launching bash script
    Fabio D'Ovidio
    fabiodovidio at gmail.com
    Thu Jan 24 10:01:05 EST 2008
hi!
I am trying Georectify tool on Windows. I have studied how it works, but
it doesn't work fine.
Are you sure that it works on Windows?
After taking my GCPs the Manager (of GCPs) doesn't show automatically
ther error for each point and when i try to calculate it, Manager
returns always 0...
So i have tried to type georectify button but the error is:
"child process exited abnormally"
please, help ;-(
Thanks
Moritz Lennert ha scritto:
> On 22/01/08 11:48, Fabio D'Ovidio wrote:
>> Hi!
>> I have installing wingrass on Windows XP following:
>> http://geog-pc40.ulb.ac.be/grass/wingrass/README
>> I have installed msys...and configured it in grass.bat
>> I have to work with v.coordinate script...how can I lauch it as a
>> bash script?
> I imagine the script attached to this mail:
> http://www.mail-archive.com/grass-italia@listserv.unipr.it/msg00440.html
> Before answering your question: my Italian is not good enough to
> really understand what this script does, but I having the feeling it
> reproduces what the "georectify" tool does when you decide to rectify
> a vector. So maybe you can just use that.
> Probably the easiest way to launch a bash script with native wingrass
> is to launch grass from within the msys shell:
> 1) Open msys shell
> 2) type /c/grass/bin/grass (not grass.bat ! - adapt path to your
> situation)
> 3) launch gis.m
> Or, if your grass.bat is correctly configured (path to sh.exe set and
> path to msys/bin and msys/lib set) you can do it from within a cmd.exe
> window:
> 1) Open cmd.exe
> 2) Launch grass in text mode: c:\grass\bin\grass.bat -text
> 3) Launch the script from the command line
> Or, if the script is in your PATH:
> 1) Launch grass in gui mode
> 2) type script name in console part of the Output window
> However, v.coordinate will not work in windows since it uses
> x-monitors. These are not supported in wingrass. So, I guess you
> really should try with the georectify tool (in the File menu).
> Moritz
Ing. Fabio D'Ovidio
iQuadro - Informatica e Innovazione s.r.l.
Via C. Pisacane 23, Aversa (CE) - 81031
Web : www.ii2.it
Tel.: 081 197 57 600
mail: fabiodovidio at gmail.com
More information about the grass-windows
