[GRASS-windows] Large file support?
Marco Pasetti
marco.pasetti at alice.it
Mon Jul 28 11:32:12 EDT 2008
Hi Johnathan,
> I seem to be running up against a file size limitation in the latest
> version of grass for windows
I made nothing different about that in the latest binary release fo Windows;
I suppose it's a generic problem, not strictly related to the latest release
> I'm trying to import a 7gb file and it seems to have imported only about
> the first 2gb or so of the file, and the rest is just empty/errored (when
> I do a v.what it gets a "can't read" in the lower 2/3 or so of the image,
> but returns correct values in the upper 1/3 or so of the image). I used
> r.in.gdal to import the file (it was an ENVI image file). Ideas?
Actually no, afraid.
If you read here
http://grass.osgeo.org/grass63/binary/mswindows/native/README.html#Release%20Notes
you can actually see that LFS is enabled.
Are you sure that the command worked fine or finished to process data?
sometimes the progress bar fails
Please, try again launching the command within the text command line (msys
or dos, as you prefer)
Please report me the results.
Regards,
Marco
More information about the grass-windows
