[GRASS-windows] WinGRASS: Test Build on Vista
Gonzalillo9a gonzalillo9a at gmail.com
Tue Jun 17 03:44:07 EDT 2008
I have installed WinGRASS-6.3.0-4 in my Windows XP profesional x64 and all
was fine, but it does not solve the
http://trac.osgeo.org/grass/ticket/111bug. When I try to execute the
following operation Windows reports me a
system failure:
r.los input=elevation.dem output=los coordinate=599505,4921010  max_dis=2525
2008/6/16 <marco.pasetti en alice.it>:
>  Hi lists,
> I built GRASS 6.3.0 on Vista (Home Premium) through the usual MSYS/MinGW
> envrironment.
> It works fine on my machine, and it seems that it solved the following
> bugs:
> http://trac.osgeo.org/grass/ticket/118
> But I need more tests, from both XP and Vista users;
> I specially need to know if that build works fine also on XP systems,
> because at the moment I cannot access my old XP machine to test it by
> myself.
> In this binary release candidate (the 4th for GRASS 6.3.0) I introduced the
> following changes:
> - added libjpeg (6b) library [built from source]
> - added JPEG support in libtiff
> - added JPEG support in GRASS
> - updated libpng from 1.2.24 to 1.2.29
> - updated GLS from 1.9 to 1.11
> - updated PostgreSQL from 8.2.6 to 8.3.1
> - updated SQLite from 3.5.6 to 3.5.9
> - added the OGDI tools (3.2.0beta1-4) [prebuilt binaries from OSGEO4W
> Project]
> - updated GDAL from 1.5.1 to 1.5.2
> - added the AVCE00 tools (2.0.0) [built from source]
> - added the E00compr tools (1.0.0) [built from source]
> - added the GPSBabel tools (1.3.5) [prebuilt binaries from GPSBabel Web
> Site]
> - updated tcl from 8.5.1 to 8.5.2
> - updated tk from 8.5.1 to 8.5.2
> I also tried to add the FFMPEG and wxWidgets supports to GRASS, but I
> failed for the moment; I'll try to do that next times :-)
> The WinGRASS-6.3.0-4 Test Installer is available here:
> http://gigamaildownload.rossoalice.alice.it/download/download.aspx?AttachmentID=f7bb562d-e5a5-4798-becd-6538000a0dc2&MessageID=f617242a-074b-4298-be4b-82ef221920ea
> Any comment or test help will be highly appreciated.
> Many thaks guys,
> Marco
> grass-windows mailing list
> grass-windows en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20080617/41da2221/attachment.html
More information about the grass-windows mailing list
