[GRASS-windows] (no subject)
Moritz Lennert
mlennert at club.worldonline.be
Wed Oct 1 16:40:09 EDT 2008
On 01/10/08 16:48, Louis Becker wrote:
> Hi
> I am trying to import the DTM files I found in the following location.
> http://www.computamaps.com/en/catalog/index_2.html
> The details given for the files are stipulated as follows.
> Format: Planet 2.8 ®, ArcInfo Grid
> Projection: UTM
> Ellipsoid: WGS84
> Resolution: DTM and Clutter 250m, Orthoimage and Map 125m
> I am able to import the DTM files if I override the projection check,
> but then of course patching files together becomes a bit difficult. Is
> there maybe an easy way out of this?
What is the projection of the location you import the files into ?
Moritz
More information about the grass-windows
