[GRASS-windows] switching to GRASS, 6.2.3 or GRASS 6.3.0?
    Glynn Clements
    glynn at gclements.plus.com
    Tue Oct  7 18:12:19 EDT 2008
Marco Pasetti wrote:
> > the path name is actually:
> > C:/Documents and Settings/Katz&Denslow
> > I think this is what you mean by username.
> OK. Finally we got it!
> I believe that the "&" is the problem!
Do you have any idea why?
Ideally, GRASS should handle any filename which is valid for the
current codepage (supporting Unicode filenames which use characters
outside of the current codepage probably isn't feasible, but that
isn't the issue here).
More information about the grass-windows
