[GRASS-windows] help with command line in GRASS 6.3
Glynn Clements
glynn at gclements.plus.com
Wed Oct 15 09:20:46 EDT 2008
Moritz Lennert wrote:
> > I run this command and I get a green line that runs along the bottom
> > of the command when it shows up in the top of the output window and
> > nothing shows in the map display. Also if I try to open a display
> > monitor by entering
> > d.mon x0
> x-monitors do not work in Windows. You have to work through the GUI, or
> directly on the cmd.exe (or msys) command line (don't think this works
> via the output window) using GRASS_RENDER_IMMEDIATE=TRUE.
Immediate rendering is always used on Windows, regardless of the value
(or lack thereof) of GRASS_RENDER_IMMEDIATE. The only reason to set it
explicitly is if you want PostScript output (GRASS_RENDER_IMMEDIATE=PS)
rather than PNG.
More information about the grass-windows
