[GRASS-windows] whitespace bug?
Stefan Muthers
stefan.muthers at zamg.ac.at
Wed Oct 22 07:02:23 EDT 2008
Hello Marco,
Marco Pasetti schrieb:
>> When I import shapefiles with whitespace in the pathname, I get an
>> error message.
> No. You simply typed the wrong command!
> Use the command GUI or type:
> v.in.ogr 'dsn=C:/Dokumente und
> Einstellungen/user/Desktop/Daten/Bsp/Example.shp' output=line
yes, I forgot dsn=, when writing the mail. The GUI was a good hint. In
Grass the dns parameter needs to be enclosed by {}
$ v.in.ogr {dsn=C:/Dokumente und
Einstellungen/muthers/Desktop/Rauigkeit/shapes/Example.shp} output=test
In Qgis your command works.
But the v.in.ogr command should be only an example.
I figured out, that in general there s a problem when using a grass
workspace with whitespace in the path.
For example:
- copy the workspace from above to C:/Dokumente und
Einstellungen/muthers/Desktop/grass
- open it with grass
$ v.db.addcol map=test columns='test INT'
ERROR: value <und> out of range for parameter <driver>
Legal range: dbf,ogr,pg,sqlite
but
$ echo ' ALTER TABLE test ADD test INT' | db.execute
works.
regards
stefan
More information about the grass-windows
