[GRASS-windows] r.sim.water
Stefan Frerichs
frerichs at bkr-ac.de
Thu Sep 11 04:16:43 EDT 2008
Hello winGrass-users,
when trying to calculate the overland flow by a heavy rainfall on a
elevation-rastermap in winGrass 6.3 with r.sim.water, i get the
error-message "Für diesen Befehl ist nicht genügend Speicher vorhanden"
(it's a german version) = "For this instruction sufficient memory is
missing" (as babelfish translates). Following are the parameters i use:
r.sim.water -t elevin=dgm at mapset dxin=dgm_dx at mapset dyin=dgm_dy at mapset
rain=surf_fractal_d50 at mapset rain_val=50 infil_val=0.0 manin_val=0.1
depth=dgm_depth disch=dgm_disch niter=10 outiter=5 diffc=0.8 hmax=0.3
halpha=4.0 hbeta=0.5
dgm_dx and dgm_dy are calculated by r.slope.aspect, surf_fractal_d50 by
r.surf.fractal with some raster-calculation to get only positive
rainfall-rates in a realistic range. It's my first attempt to run
r.sim.water to see, how it is working and how do the results look like.
I'm working with WinGrass 6.3 on a WinXP Pro, Pentium 4 with 2.8 Ghz,
2.5 GB physical Ram and around 2 GB virtuell Ram.
Searching in the list doesn't help me so far. Please, can someone give
me a hint, how to solve the problem to run r.sim.water successfully?
And, please, be patient with me, i'm more user then programmer ...
Greetings and thanks in advance
Stefan
More information about the grass-windows
