[GRASS-windows] r.sim.water
    Stefan Frerichs
    frerichs at bkr-ac.de
    Thu Sep 11 05:01:51 EDT 2008
Hi Markus,
g.region -p have following output:
rojection: 99 (Transverse Mercator)
zone:       0
datum:      potsdam
ellipsoid:  bessel
north:      5652051.21010544
south:      5627951.21010544
west:       2509969.37538876
east:       2540019.37538876
nsres:      25
ewres:      25
rows:       964
cols:       1202
cells:      1158728
("rojection" sic!)
The Map-Unit is meter, as the elevation-raster comes in Gauß-Krüger
Stefan
Markus Neteler schrieb:
> On Thu, Sep 11, 2008 at 10:16 AM, Stefan Frerichs <frerichs at bkr-ac.de> wrote:
>> Hello winGrass-users,
>> when trying to calculate the overland flow by a heavy rainfall on a
>> elevation-rastermap in winGrass 6.3 with r.sim.water, i get the
>> error-message "Für diesen Befehl ist nicht genügend Speicher vorhanden"
>> (it's a german version) = "For this instruction sufficient memory is
>> missing" (as babelfish translates). Following are the parameters i use:
>> r.sim.water -t elevin=dgm at mapset dxin=dgm_dx at mapset dyin=dgm_dy at mapset
>> rain=surf_fractal_d50 at mapset rain_val=50 infil_val=0.0 manin_val=0.1
>> depth=dgm_depth disch=dgm_disch niter=10 outiter=5 diffc=0.8 hmax=0.3
>> halpha=4.0 hbeta=0.5
>> dgm_dx and dgm_dy are calculated by r.slope.aspect, surf_fractal_d50 by
>> r.surf.fractal with some raster-calculation to get only positive
>> rainfall-rates in a realistic range. It's my first attempt to run
>> r.sim.water to see, how it is working and how do the results look like.
>> I'm working with WinGrass 6.3 on a WinXP Pro, Pentium 4 with 2.8 Ghz,
>> 2.5 GB physical Ram and around 2 GB virtuell Ram.
>> Searching in the list doesn't help me so far. Please, can someone give
>> me a hint, how to solve the problem to run r.sim.water successfully?
>> And, please, be patient with me, i'm more user then programmer ...
> Please post the output of
> g.region -p
> Possibly you are at nanometer resolution?
> Markus
_____________________________________________________
BKR Aachen                     Kirberichshofer Weg 6
Castro & Hinzen                D-52066 Aachen
Stadtplaner, Umweltplaner      Fon +49 241 47058-0
                               Fax +49 241 47058-15
Amtsgericht Essen PR 43        www.bkr-ac.de
More information about the grass-windows
