[GRASS-windows] Re: r.sim.water
Markus Neteler
neteler at osgeo.org
Sat Sep 13 04:37:16 EDT 2008
On Sat, Sep 13, 2008 at 2:18 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> > thanks for testing - I think simwe has a problem on MSwindows due to
>> > the problem with sites to vector update - that is why Glynn has disabled
>> > it.
>> when was it disabled (don't remember)? Post-6.3.?
> Only in 7.x.
> The compatibility wrappers use a "FILE *" in their interfaces, which
> is cast to/from a "struct Map_info *" internally. In 7.x, I changed
> this to use the correct type, and changed any code which uses those
> functions.
This had been backported to 6.4.svn.
> Except that simwe has some mismatches, e.g. using G_sites_close() on a
> normal text file and using fclose() on a "pseudo-FILE*". With the
> changes to lib/sites, simwe doesn't compile, and I couldn't understand
> the code well enough to fix it, so I disabled it.
I have now backported small fixes (essentially code order to do some
computations post-parser instead of ante-parser. But that's not
relevant.
I have now compared simwe/ in 6.3.svn (after updating the code
layout there to the new rules) to 6.4.svn. Besides above mentioned
core-reorder, the only difference is:
diff -ru --exclude=.svn
/home/neteler/grass63_release/raster/simwe/simlib/output.c
--- /home/neteler/grass63_release/raster/simwe/simlib/output.c 2008-09-13
10:28:51.000000000 +0200
+++ simwe/simlib/output.c 2008-08-05 00:05:02.000000000 +0200
@@ -57,6 +57,8 @@
if (fdoutwalk == NULL)
G_fatal_error("Cannot open %s", outwalk);
else {
+ char buf[GNAME_MAX + 40];
if (NULL == (sd = G_site_new_struct(-1, 2, 0, 1)))
G_fatal_error("memory allocation failed for site");
@@ -65,9 +67,8 @@
else
walkershead.name = outwalk;
- walkershead.desc = G_strdup("output walkers");
- walkershead.desc = (char *)G_malloc(128 * sizeof(char));
- sprintf(walkershead.desc, "output walkers of %s [raster]", depth);
+ sprintf(buf, "output walkers of %s [raster]", depth);
+ walkershead.desc = G_store(buf);
walkershead.time = NULL;
walkershead.stime = NULL;
walkershead.labels = NULL;
Could this missing update in 6.3.svn cause a crash on Windows?
A real candidate is the update to lib/sites/sites.c which isn't in GRASS 6.3.svn
yet:
--- /home/neteler/grass63_release/lib/sites/sites.c 2008-09-13
10:34:16.000000000 +0200
+++ ../lib/sites/sites.c 2008-08-05 00:05:18.000000000 +0200
@@ -50,16 +50,13 @@
* -2 on other fatal error or insufficient data,
* 1 on format mismatch (extra data)
-int G_site_get(FILE * fptr, Site * s)
+int G_site_get(struct Map_info *Map, Site * s)
int i, type, cat;
- struct Map_info *Map;
static struct line_pnts *Points = NULL;
static struct line_cats *Cats = NULL;
SITE_ATT *sa;
- Map = (struct Map_info *)fptr;
if (Points == NULL)
Points = Vect_new_line_struct();
if (Cats == NULL)
@@ -115,14 +112,11 @@
/* Writes a site to file open on fptr. */
-int G_site_put(FILE * fptr, const Site * s)
+int G_site_put(struct Map_info *Map, const Site * s)
if (Points == NULL)
if (Cats == NULL)
@@ -156,12 +150,9 @@
* -1 on EOF,
* -2 for other error.
-int G_site_describe(FILE * ptr, int *dims, int *cat, int *strs, int *dbls)
+int G_site_describe(struct Map_info *Map, int *dims, int *cat, int *strs,
+ int *dbls)
- Map = (struct Map_info *)ptr;
if (Vect_is_3d(Map)) {
G_debug(1, "Vector is 3D -> number of site dimensions is 3");
*dims = 3;
@@ -184,13 +175,10 @@
* Writes site_head struct.
-int G_site_put_head(FILE * ptr, Site_head * head)
+int G_site_put_head(struct Map_info *Map, Site_head * head)
static char buf[128];
if (head->name != NULL)
Vect_set_map_name(Map, head->name);
@@ -223,7 +211,8 @@
return -1; /* added to prevent crash 5/2000 MN */
- G_format_timestamp(head->time, head->stime);
+ G_format_timestamp(head->time, buf);
+ head->stime = G_store(buf);
Vect_set_date(Map, head->stime);
@@ -234,12 +223,8 @@
* Fills in site_head struct.
-int G_site_get_head(FILE * ptr, Site_head * head)
+int G_site_get_head(struct Map_info *Map, Site_head * head)
head->name = Vect_get_name(Map);
head->desc = Vect_get_comment(Map);
head->form = NULL;
@@ -293,11 +278,11 @@
* rejects all names that begin with .
- * FILE *
+ * struct Map_info *
* G_sites_open_old (name, mapset)
* opens the existing site list file 'name' in the 'mapset'
- * FILE *
* G_sites_open_new (name)
* opens a new site list file 'name' in the current mapset
@@ -343,7 +328,7 @@
-FILE *G_sites_open_old(char *name, char *mapset)
+struct Map_info *G_sites_open_old(const char *name, const char *mapset)
struct field_info *fi;
@@ -376,7 +361,7 @@
fi = Vect_get_field(Map, 1);
if (fi == NULL) { /* not attribute table */
G_debug(1, "No attribute table");
- return (FILE *) Map;
+ return Map;
driver = db_start_driver_open_database(fi->driver, fi->database);
@@ -476,11 +461,11 @@
qsort((void *)Map->site_att, Map->n_site_att, sizeof(SITE_ATT),
site_att_cmp);
+ return Map;
-FILE *G_sites_open_new(char *name)
+struct Map_info *G_sites_open_new(const char *name)
@@ -494,16 +479,13 @@
G_debug(1, "New vector map opened");
+ return Map;
-void G_sites_close(FILE * ptr)
+void G_sites_close(struct Map_info *Map)
int i, j;
if (Map->mode == GV_MODE_WRITE || Map->mode == GV_MODE_RW)
Vect_build(Map, stderr);
@@ -530,19 +512,19 @@
/* compatability while porting applications */
-FILE *G_fopen_sites_old(char *name, char *mapset)
+struct Map_info *G_fopen_sites_old(const char *name, const char *mapset)
return G_sites_open_old(name, mapset);
-FILE *G_fopen_sites_new(char *name)
+struct Map_info *G_fopen_sites_new(const char *name)
return G_sites_open_new(name);
-int G_get_site(FILE * fd, double *east, double *north, char **desc)
+int G_get_site(struct Map_info *fd, double *east, double *north, char **desc)
/* TODO ? */
G_fatal_error("G_get_site() not yet updated.");
@@ -551,7 +533,8 @@
-int G_put_site(FILE * fd, double east, double north, const char *desc)
+int G_put_site(struct Map_info *fd, double east, double north,
+ const char *desc)
/* TODO ? */
G_fatal_error("G_put_site() not yet updated.");
@@ -1209,20 +1192,13 @@
Functions to obtain fields in order to draw sites with each point having a
geometric property depending from database values.
- IN ALL THESE FUNCTIONS I FOLLOW THE CONVENTION TO PASS Map_info* as FILE*
- FOR COHERENCE WITH OTHER ALREADY WRITTEN FUNCTION IN sites.c FILE.
Returns a pointer to the SITE_ATT in Map_info *ptr and with category cat
-SITE_ATT *G_sites_get_atts(FILE * ptr, int *cat)
+SITE_ATT *G_sites_get_atts(struct Map_info * Map, int *cat)
return (SITE_ATT *) bsearch((void *)cat, (void *)Map->site_att,
site_att_cmp);
@@ -1233,13 +1209,13 @@
WARNING: user is responsible to free allocated memory, directly or
calling G_sites_free_fields()
-int G_sites_get_fields(FILE * ptr, char ***cnames, int **ctypes, int **ndx)
+int G_sites_get_fields(struct Map_info *Map, char ***cnames, int **ctypes,
+ int **ndx)
int nrows, row, ncols, col, ndbl, nstr, ctype;
- char *name;
+ const char *name;
dbDriver *driver;
dbString stmt;
dbCursor cursor;
@@ -1254,7 +1230,6 @@
Should it be not true in the future, maybe we'll have to
change this by choosing
appropriate fields and multiple categories */
fi = (struct field_info *)Vect_get_field(Map, 1);
On the other hand, fixing 6.3.svn is a waste of time since we'll
branch of a release branch for 6.4.svn soon. Then release
candidates will be created and hopefully a new WinGRASS package.
> [It doesn't help that there are various other problems with the code,
> e.g. each module having a private copy of waterglobs.h which doesn't
> necessarily match simlib.]
Markus
More information about the grass-windows
