[GRASS-windows] r.sim.water
Helena Mitasova hmitaso at unity.ncsu.edu
Thu Apr 9 12:39:36 EDT 2009
I have specifically removed the site related code to get r.sim.water
running on windows but apparently
there is still a problem - we will try to test it here to see what the
problem may be.
Thaks for testing,
Helena
P.S. Floris, I got your email - sorry for not responding yet - I have
your email in my 250 emails long list
that require answer or action, I just did not get to it yet.
On Apr 9, 2009, at 12:00 PM, grass-windows-request at lists.osgeo.org
wrote:
> Message: 1
> Date: Thu, 9 Apr 2009 12:36:19 +0200
> From: Markus Neteler <neteler at osgeo.org>
> Subject: Re: [GRASS-windows] r.sim.water
> To: Floris Van Ogtrop <f.vanogtrop at usyd.edu.au>
> Cc: grass-windows at lists.osgeo.org
> Message-ID:
> 	<86782b610904090336r4b965990q8920056a378434f3 at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> On Thu, Apr 9, 2009 at 2:09 AM, Floris Van Ogtrop
> <f.vanogtrop at usyd.edu.au> wrote:
>> Hello Markus,
>>        I tried the new GRASS 6.4.0RC3 binaries (which looks good!).
>> Unfortunately the problem persists.
>> #Note that r.slope.aspect and r.mapcalc work perfectly#
>> g.region rast=elevation.dem -p
>> r.slope.aspect --o elevation=elevation.dem dx=DX dy=DY
>> r.mapcalc Rain=if(elevation.dem, 5, null())
>> r.mapcalc Manin=if(elevation.dem, 0.05, null())
>> r.mapcalc Infil=if(elevation.dem, 0, null())
>> r.sim.water --o elevin=elevation.dem dxin=DX dyin=DY rain=Rain
>> manin=Manin infil=Infil depth=Depth
>> #Crashes after 1 minute
> I have polished the r.sim.water manual page and added your synthetic
> example (using the higher res elevation.10m):
> http://trac.osgeo.org/grass/changeset/36660
> both DEMs work for me... I am afraid that debugging is needed
> on Windows.
> Markus
> Message: 2
> Date: Thu, 09 Apr 2009 14:36:29 +0200
> From: Martin Mainzer <martmai at gmx.de>
> Subject: [GRASS-windows] OSGeo4W installer: problems with the
> 	tcl/tk-GUI (GRASS 6.4.0RC3) on W2k
> To: grass-windows at lists.osgeo.org
> Message-ID: <49DDEBCD.5050909 at gmx.de>
> Content-Type: text/plain; charset=ISO-8859-15; format=flowed
> Hello,
> I just installed the GRASS6.4.0RC3 with the OSGeo4W installer on my
> windows 2000 machine.
> Within the tcltk-GUI it is not possible to select a map within the
> project:
> I clicked 'Add vector layer', then on the icon in the lower part of
> the
> GIS Manager 'vector map to display'. Within the following pop-up
> window
> there are no maps listed. With the 'g.list type=vect' command
> entered in
> the GIS.m window, all vector maps are listed as expected. And it is
> also
> possible to show the maps by entering the names of the maps in the
> 'Vector map'- field in the lower part of the GIS Manager. Just
> selecting
> with the icon is not possible.
> Is this a windows 2000 problem or a bug within the GRASS6.4.0RC3?
> Another error occurred working with the tcltk-GUI:
> Using the 'Show attribute data' button within the 'GIS Manager' window
> the following command is sent to be executed:
> db.select table=veg_buffer_1_dissolve
> database=D:\daten\GISDataBase/demolocation/PERMANENT/dbf/ driver=dbf
> For this command I get the following error in the output:
> # BMI-DBF driver error:
> # Cannot create dbf database:
> # D:datenGISDataBase/demolocation/PERMANENT/dbf/
> # Unable to open database
> # <D:datenGISDataBase/demolocation/PERMANENT/dbf/>
> Notice: the \ are gone!
> By correcting the command manually (backslash to slash) to:
> database=D:/daten/GISDataBase/demolocation/PERMANENT/dbf/ driver=dbf
> everything works fine.
> Martin
> Message: 3
> Date: Thu, 9 Apr 2009 15:03:10 +0200
> Subject: Re: [GRASS-windows] OSGeo4W installer: problems with the
> To: Martin Mainzer <martmai at gmx.de>
> Message-ID:
> 	<86782b610904090603i3428062al363186293f36c05a at mail.gmail.com>
> On Thu, Apr 9, 2009 at 2:36 PM, Martin Mainzer <martmai at gmx.de> wrote:
>> Hello,
>> windows
>> 2000 machine.
>> project:
>> the
>> window
>> entered in
>> also
>> selecting
>> window the
> the code in
> gui/tcltk/gis.m/vector.tcl
> GmVector::show_data{}
>                set cmd "db.select table=$tbl database=$db driver=$drv"
> needs apparently a compatibility fix (g.dirseps?).
> Markus
> Message: 4
> Date: Thu, 9 Apr 2009 11:02:36 -0400
> From: Colin Nielsen <colin.nielsen at gmail.com>
> Message-ID:
> 	<d4e057e20904090802n778afdbev87e0ab0d8a931641 at mail.gmail.com>
> I noticed the Add layer problem as well so it's not a win2k problem. I
> think that error has been fixed since, because it seems to be fine in
> the native installer I put together.
> -Colin
> On Thu, Apr 9, 2009 at 8:36 AM, Martin Mainzer <martmai at gmx.de> wrote:
>> Hello,
>> windows
>> 2000 machine.
>> project:
>> the
>> window
>> entered in
>> also
>> selecting
>> window the
>> Martin
>> grass-windows mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-windows
> End of grass-windows Digest, Vol 32, Issue 9
More information about the grass-windows mailing list
