[GRASS-windows] question about r.li
dbormpou
dbormpou at bio.auth.gr
Mon Feb 9 06:57:22 EST 2009
Thanks for the advice once more, but i am having problems with cygwin also.
I have progressed with the installation till
''To start GRASS, double-click on the Cygwin icon and run "startx" at the
command prompt. This will start X-Windows and open a new xterm window. At
the xterm prompt type "grass63".''
I type startx press enter and all i get is
''bash: startx: command not found''
I have also tried it from the run process in windows as the cygwin website
guide says, but it doesnt work either.
I am complete novice in these matters so bear with me
Thanks
Dimitris
dbormpou wrote:
> Ok, thanks a lot i will try it with that version
> Dimitris
> Marco Pasetti-3 wrote:
>> Dimitris,
>>> i am a new gis user and i am trying my way with GRASS.
>>> Do you know why i cannot use the r.li suite neither non vista or xp?
>> Because the r.li suite is not compiled in the native MS-Windows version
>> of
>> GRASS; and this is because MS-Windows doesn't support monitors.
>>> Is there a way i can use it from a windows OS?
>> Yes, using the cygwin version of GRASS:
>> http://grass.osgeo.org/grass63/binary/mswindows/cygwin/
>> Regards,
>> Marco
>> grass-windows mailing list
>> grass-windows at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-windows
View this message in context: http://n2.nabble.com/question-about-r.li-tp2284583p2296855.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows
