[GRASS-dev] Re: [GRASS-windows] windows qgis-grass: make grass
build with vc or keep a separate qgis-grass mingw build?
G. Allegri
giohappy at gmail.com
Fri Mar 27 05:30:29 EDT 2009
> I am not aware of any postings in this regard from Marco.
> Please point us to that to better understand the issues he found.
I've just asked him if he can partecipate to the discussion to explain this...
> Question: Did you try to update the installer from Marco? Maybe
> it works out of the box with a few minor tweaks? It is in the
> mswindows/ directory in the source code.
No problems with mingw build. I've already built grass6_devel from
scratch, and it almost works (better then the one I've built against
osgeo4w libs):
1 - wxdigit and wxnviz don't work, but I know that Martin is working
on this right now
2 - Marco told me that there soudl be made some changes to update the
build system. I still have to dig in this, but there are reasons to
hope that Marco, maybe, will find some time to work on this...
3 -qgis bindings. With osgeo4w, on windows Vista, qgis crashes
whatever you try to do with the plugin: db.exe returns and makes Qgis
crash. I don't know yet if it's the same problem with memory
management or what else.
In any case the questions remain:
1 - continue to build grass with MingW?
1a: build it against MinGW built libs (not osgeo4w)?
1b: build it against vc built libs (osgeo4w)?
2 - build Qgis with vc (osgeo4w) and solve the bindings problems with
Grass: 1a or 1b?
More information about the grass-windows
