[GRASS-windows] r.stats | awk | reclass under WinGrass OSGeo4W
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Sat Mar 28 13:23:39 EDT 2009
Dear all,
I need to proceed the following command
r.stats -na input=mymap | awk '{print $1,"=",int($2/10000)+1}'|r.reclass
input=mymap output=mymap_areaha - --o
When running wingrass6.3 under MSys/MINGW It worked so fine.
But now I am running Wingrass 6.4 (OSGeo4W distribution) in text mode
(started from OSGeo4W Shell) but bash commands don't work.
I tryed to start WinGrass from MSYS(MINGW - C:\OSGeo4W\apps\msys)
but when I type grass64 I got the following error message:
Starting GRASS ...
WARNING: The wish command does not work as expected!
Please check your GRASS_WISH environment variable.
Use the -help option for details.
Switching to text based interface mode.
Hit RETURN to continue.
Any help are Welcome.
Best wishes
milton
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090328/17708d12/attachment.html
More information about the grass-windows mailing list
