[GRASS-windows] CompileOnWindows finished
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Sat Mar 28 19:51:49 EDT 2009
Hi Colin,
Sorry, I really forgot the zlib-devel. My mistake.
But now I compiled and I have other issue.
When I start MSys, and define GRASS_WISH,
and execute GRASS I get the box to select
my MAPSET. After that I get the following error message:
This application has failed to start
because libintl3.dll was not found.
Re-installing the application may fix this problem.
Any idea? I need do compile GRASS again (how can I recompile?).
Best wishes
miltinho
Toronto, CA
2009/3/28 Colin Nielsen <colin.nielsen at gmail.com>
> I believe you're missing the zlib-devel package, it contains zlib.h.
> (Re-)install this package, then try again. If it still fails, verify
> that zlib.h is in /osgeo4w/include. If it is there but is still
> failing let us know.
> -Colin
> On Sat, Mar 28, 2009 at 4:47 PM, Milton Cezar Ribeiro
> <miltinho.astronauta at gmail.com> wrote:
> > Dear Colin,
> > Thank you very much for your great work.
> > I am trying to follow your steps on a 64bit Vista Machine,
> > and got the following error.
> > checking for socket... no
> > checking for socket in -lsocket... no
> > configure: warning: *** Unable to locate socket() function.
> > checking for location of zlib includes...
> > checking for zlib.h... no
> > configure: error: *** Unable to locate zlib includes.
> > Any idea?
> > Best wishes,
> > milton
> > Toronto, CA
> >> I just wanted to announce that the CompileOnWindows wiki entry
> >> <http://trac.osgeo.org/grass/wiki/CompileOnWindows> is finished and
> >> now allows anyone to develop grass on windows (vista or xp) through
> >> the mingw/msys system with no dependency compiling and relatively
> >> little extra work (thanks to jef for solving all remaining issues by
> >> adding the mingw-libs package to the wiki).
> >> -Colin
> >> _______________________________________________
> >> grass-windows mailing list
> >> grass-windows at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-windows
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090328/39d4e678/attachment-0001.html
More information about the grass-windows
