[GRASS-windows] Location Wizard Problem
Markus Neteler neteler at osgeo.org
Tue Jan 12 03:27:15 EST 2010
On Sun, Jan 10, 2010 at 6:23 PM, MJ <mlc652 at gmail.com> wrote:
> I am running the Windows version of Grass 6.4.0 (installed from native
> version wingrass-6.4.osvn-r40049-1-setup.exe).  When I try to execute
> the following, I have problems.
> * Launch GRASS
> * On the right-hand side select Location Wizard under Define new location
> * Leave the GIS Data Directory field as is but choose a descriptive
> name for the Project Location
> * Continue to the next page
> * Choose Select Coordinate System parameters from a list and continue
> * Type in ll for the Projection Code or scroll down the page to find Lat/Lon
> * Choose Dataum with associated ellipsoid
... ok.
> When I try to enter a Central Parallel or Central Meridian, nothing
> changes occur in the entry boxes.  I can highlight the default zero
> values, but I am unable to change them.
Why would you want to change these values for LatLong?
> If I now click Next, I get the error "Something is Missing.  You must
> enter a value for Central Meridian"
Here it works (using a slightly more recent version from SVN).
> The same thing happens if I Choose the Ellipsoid Only option.
> How dows one move past this page? Am I doing something wrong, or is this a bug?
A bug.
The question is if it was fixed recently or not. A Windows user
will have to check this with the current SVN version.
Here on Linux with current SVN it is ok.
Markus
More information about the grass-windows mailing list
