[GRASS-windows] run grass in command line
maven apache
apachemaven0 at gmail.com
Mon Mar 1 00:06:43 EST 2010
HI:
I want to run grass in a command line model, however when I write a bat,it
works just for 6.3 version , and some command can not work for example I can
run g.version ,rather than r.fillnulls.
The grass variable bat is :
@echo off
rem *******Environment variables***********
rem Set GRASS Installation Directory Variable
set GRASSDIR=F:\anzhuang\GRASS
rem set GISBASE=D:\GrassDataBase
set GISRC=C:\Documents and Settings\Administrator\.grassrc6
rem Set Path to utilities (libraries and bynaries) used by GRASS
set PATH=%GRASSDIR%\msys\bin;%PATH%
set PATH=%GRASSDIR%\extrabin;%GRASSDIR%\extralib;%GRASSDIR%\extrabin;%PATH%
set
PATH=%GRASSDIR%\tcl-tk\bin;%GRASSDIR%\sqlite\bin;%GRASSDIR%\gpsbabel;%PATH%
set
PATH=%PATH%;%GRASSDIR%\bin;%GRASSDIR%\lib;%GRASSDIR%\scripts;%GRASSDIR%\etc;%GRASSDIR%\sqlite\lib;%GRASSDIR%\sqlite\bin;
rem Path to the proj files (notably the epsg projection list)
set GRASS_PROJSHARE=%GRASSDIR%\proj
And I write a work bat :
r.in.gdal
input=D:\data\hdf5\new\OMI-Aura_L3-OMTO3e_2009m0729_v003-2009m0731t020127.tif
output=aa location=al
g.gisenv set=LOCATION_NAME=al
g.region rast=aa
r.null map=aa setnull=-1.267e+30--1.268e+30
r.fillnulls input=aa output=ab tension=40 smooth=0.1
r.out.gdal input=ab format=GTiff
output=D:/OMI-Aura_L3-OMTO3e_2009m0729_v003-2009m0731t020127.tif
It does not work, it tell me that the r.fillnulls is not a valide command.
I wonder why?
In fact what I am trying to do is to call grass in my web application(like
the web processing service),now I want to handle the hdf5 data,the following
is my idea:
1) use gdalinfo to get the information of the he5,(the gdal model in grass
6.3 does not support this command, the 6.4 support)
2) change the subdataset to geotiff, use gdal_translate
3) import the tiff to grass and create a new location according the tif
4) log in to the new location use g.gisenv
5) set some sepical cell data to null by using r.null....
6) Interpolation the null data using r.fillnulls.
7) export the map to geotiff.
So anyone can give some advise?
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20100301/0d3c89ff/attachment.html
More information about the grass-windows
