[GRASS-windows] GUI with python scripts or shell scripts
Sonja Jankowfsky
sonja.jankowfsky at cemagref.fr
Wed Mar 3 07:10:09 EST 2010
I did some more tests on my machine on this subject and what I get is this:
I don't get an interface with the grass parser on my windows machine,
neither with a shell script running through Msys, nor a python script
running through the windows commandline. However, I can enter the
variables as normal GRASS command on my command line:
test.py input=ditch.shp output=ditch1
test.sh input=ditch.shp output=ditch1
Is this a common bug?
Sonja
On 1/29/2010 7:25 PM, Glynn Clements wrote:
> What do you get from:
> junk.py --interface-description
Here is the output
GRASS 6.4>
F:\\AMNH\\WHRC_CarbonProject\\R_Project\\PercentCoverTutorial\\junk.
GRASS 6.4> <?xml version="1.0" encoding="CP1252"?>
<!DOCTYPE task SYSTEM "grass-interface.dtd">
<task name="junk.py">
<description>
g.parser test script (python)
</description>
<parameter name="raster" type="string" required="yes" multiple="no">
<description>
Raster input map
</description>
<gisprompt age="old" element="cell" prompt="raster" />
</parameter>
<parameter name="vector" type="string" required="yes" multiple="no">
<description>
Vector input map
</description>
<gisprompt age="old" element="vector" prompt="vector" />
</parameter>
<parameter name="option1" type="string" required="no" multiple="no">
<description>
An option
</description>
</parameter>
<flag name="f">
<description>
A flag
</description>
</flag>
<flag name="verbose">
<description>
Verbose module output
</description>
</flag>
<flag name="quiet">
<description>
Quiet module output
</description>
</flag>
</task>
More information about the grass-windows
