[GRASS-windows] Re: Install problem with GRASS 6.4.0.RC1
MOREL Stéphane
stephanemorel12 at gmail.com
Mon May 3 02:37:43 EDT 2010
Hi all,
I finally find out what is going wrong with this g.proj.exe with the
help of dependacy walker. I ran dependancy walker and choose g.proj for
the file and he found an old gdal13.dll in in windows system32 and some
other files like geotiff.dll geos_c.dll. I don't know why they are here
but after renaming those files I can launch Grass without any troubles
If it can helps others
S.
Le 29/04/2010 11:04, Stéphane Morel a écrit :
> Hi all,
> As mentioned in the object, I have some issues getting grass working
> properly(downloaded from
> http://grass.osgeo.org/grass64/binary/mswindows/native/). As shown on
> the image one, at the end of the install I have an error message
> indicating the copy has failed. nevertheless, the install goes on and
> end up whithout other problems. I can launch grass, choosing a
> dataset/location , but when after hitting the enter button there is a
> second error message stating an error with g.proj. No additional
> information is provided.
> I don't know if there is a link between this two errors.
> additional info : the previous install Grass 6.3 works perfectly well,
> downloaded from OSGeo4W
> Thanks in advance for your help
> Stephane
More information about the grass-windows
