[GRASS-windows] can't start GRASS-error setting the coordinate
	system?
    cove_adrian
    covasnianu.adrian at gmail.com
    Sun Nov 21 09:13:18 EST 2010
Hello!
I'm new to this forum and hopefully I'm posting in the right area. :)
I've installed Grass 6.4.0. for Windows. Next I want to set my new location
(using location wizard) and set the coordinate system (current case -
31700).After that I'm getting an error.
I'm attaching the image
http://osgeo-org.1803224.n2.nabble.com/file/n5760187/grass2.jpg
I've tried also default - no modification of project location (demolocation)
and accesible mapsets (PERMANENT) and the same error occurs saying Execution
failed : 'g.proj-p'.
WHY?
I've uninstalled the program, run again and the same errors appears once
again.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/can-t-start-GRASS-error-setting-the-coordinate-system-tp5760187p5760187.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows
