Louis Becker wrote: > I want to use db.execute in a script, but can't get it working. > > Trying: > > Echo "select * from Coverage2011_4" | db.execute In Windows' shell (cmd.exe), the quotes will be retained, causing a syntax error; try: Echo select * from Coverage2011_4 | db.execute -- Glynn Clements <glynn at gclements.plus.com>
