[GRASS-windows] db.execute not working
Louis Becker Louis.Becker at leo.na
Mon Oct 11 05:15:08 EDT 2010
Hi Glynn
Yes, the problem is the select statement. I have now been able to update
a table by dropping the quotation marks.
Thanks
Louis Becker
> -----Original Message-----
> From: Glynn Clements [mailto:glynn at gclements.plus.com]
> Sent: 07 October 2010 10:42
> To: Louis Becker
> Cc: grass-windows at lists.osgeo.org
> Subject: RE: [GRASS-windows] db.execute not working
> Louis Becker wrote:
> > DBMI-SQlite driver error:
> > Error in sqlite3_step()
> > not an error
> > ERROR: Error while executing: 'select * from Coverage2011_4
> I don't know if it's related, but you probably shouldn't be using
> db.execute for a select statement. You would normally use db.select
> for queries.
> Glynn Clements <glynn at gclements.plus.com>
DISCLAIMER
This message is intended solely for the individual(s) and entity(s) to which it is addressed.  It is confidential and may contain legally privileged information.
Any unauthorized review, use, copying, storage, disclosure or distribution of this e-mail and any attachments is strictly prohibited.  If you are not the named
recipient or have otherwise received this communication in error, please destroy this message from your system and kindly notify the sender by e-mail.
More information about the grass-windows mailing list
