[GRASS-windows] Re: grass-windows Digest, Vol 49, Issue 1
Hanlie Pretorius hanlie.pretorius at gmail.com
Fri Sep 3 04:27:30 EDT 2010
> Date: Thu, 2 Sep 2010 01:00:19 -0700 (PDT)
> From: rasmus borgstr?m <rb at gras.ku.dk>
> Subject: [GRASS-windows] Re: Command line problems
> To: grass-windows at lists.osgeo.org
> Hi Hanlie
> I am trying to make a windows bat file that has to start up GRASS GIS and do
> some processing of images and then exit again.
> Is there any chance I can get some help from you, i.e. by posting your bat
> file etc?
> Best regards
> Rasmus
Hi Rasmus
I never did get a batch file to work. I managed to get the msys
shortcut working (i.e. GRASS starts from inside an MSYS shell) on one
computer (Win XP SP3) by adding the following to the PATH environment
variable:
C:\Program Files\GRASS-64\msys\bin;C:\Program Files\GRASS-64\extrabin
However, on another computer (Win XP SP1) this didn't work. The GRASS
versions were the same on the two computers (64RC6).
HTH
Hanlie
More information about the grass-windows mailing list
